Yes, these are beautiful boats. And, you're not nuts what so ever, in any shape or form. Having only one boat seems as unnatural as asking me to have just one beer. Heaven forbid!
A shower in the v-berth? You bet. One thing I've noticed is ingenuity runs rampant in this forum. If you really want it, it can happen.
It looks like you allready have a post production drain added to the aft of your boat. What's the story behind that?
Hi Tony BEST of the season you ya. The "drains" you speak of are 2 factory "scuppers" on either side of the cockpit side deck. I noticed #50 has different cabinetry above both settees also. Could it be the early production models had things that were later dropped ?? The drain at the base of the keel was owner installed , I presume to allow any deck leak water to run out during storage. The decks are now re-cored and everything re-bedded so NO MORE LEAKS!I will post pics of the cabinetry when I figure out how to get pics posted. take care Frank
Frank, A-50's "cabinetry above both settees" is custom by some previous owner. Ditto the companion way door, the cover on the chain locker and the deck scuppers. Early boat's scuppers were 1/2 inch leading to above the water line through hull fittings. Not real efficient. Later boats had one inch scuppers, but in all caes, as the hull laminate saturated, hardware was added and gear got stowed, the low point usually moved aft . . . leaving the scuppers forward of the point where water tends to collect when the boat is docked. Filling the water tank and moving gear forward (& storing the ob on the cabin sole) will help.
