I plan on it.Right now I'm a little worried as revival is real close to 'wilma' in central Forida.I've got new hull mount chain plates made up,a dodger,main cover and jib bag,cushions covered etc and I plan to go down approx Nov 16 to complete things.I'm bringing the standing rigging home with me in early Dec. to have it replaced(afraid to have it made off of book measurements just in case) I'll go back down in mid Jan. to install the rigging ,step the mast and sail #50 for the 1st time in 32mths of ownership.CAN"T WAIT !!! A couple of shake down sails and we are off to the Abacos until early April.Can't waite for that either.Seriously cosidering paying the 27% duty and keeping her there.Would be TOO easy to fly right there and be exploring day one of holiday.
Sounds great! I'm especially interested in your "hull mount chain plates". Personally, I think they sound very practical, easy to inspect, and look very "shippy" to boot. Keep the pictures coming!
Frank,
Remember your Pink Pearl, don't leave home without it!
You're at the boat, I believe, installing outboard chainplates. We may have had discussion about this event on another thread. I'm preparing 338's while you are actually doing it.
What are you doing about the main bulkhead. Aussie Geoff's are installed on the aft side. My figuring puts the new location at least 1 1/2" back of its original position. Upper shrouds are on the centerline of the mast. Are you going to move the mast base aft? (My measure says the mast goes off support from the beam, in it's designed position it's only half on the beam.) If not. what is your observation?
All the chainplates aft to avoid the bulkheads and not moving the mast means maybe using Kurt's method of solving the offset by connecting the tops of the new plates with a bar and attaching the shrouds back to the bar in their designed position. Have you another way?
Figure the wider spread is about 3"OA - will the existing rigging still fit?
Aesthetically, are you going to tilt the plates on the hull to line up with the shrouds? With the number of bolts we put in lining them up parallel would be more spiffy and given the small angle, arguably just a strong.?? Gonna bend the tops in? Much easier if them all have the same bend. And if the Kurt Bar is used the loads are further shared by being interconnected. Which might be the settling arguement for having the six shroud plates all perpendicular to the waterline.
In fact the bar would allow the plates to be attached to the hull in their most convenient location. Bar adds unwanted weight and shroud attachments on any cantilevered location would be dangerous. This begs that the forward lower plate be located forward of it's original position. This would allow all rigging connections to be inside the ends of the kurtbar. Sure would like to talk this thru till it got clear!!! Like for instance, what loads are put on the bar? What section would it have to be? Corse I always make things more complicated!!!
Recording this event for us? Hope your weather cooperates!
Ebb I'm not back to the boat until approx the 18-19th of nov. I plan on copying our Aussie friends plates. I favour the 'keep it simple-stupid' approach...being of lessor intelligence and failing patiance. I will post pics as I go. Picked up the new cockpit cushions etc yesterday...they look great.Hope they all fit as my favorite sail/cushion maker is up here so he never actually saw the boat...just a piece of paper and my measurements.It's the 'my measurement' thing that scares me.
Here's a great little 'fold up' 12w charger that stows super small and easy!!Bought in Canada @ a "Canadian Tire' store...don't know if available State side ?? I simply tie unto the sunny side cabin hand rail and plug into the lighter socket on the electrical panel
