Results 1 to 15 of 422
Thread: Commander 147
Threaded View
  1. #11
    Chance
    The paint I'm using is Pettit EZ Cabin Coat mold and mildew resistant paint. It is a water based paint that has a semi gloss appearance. The first batch of it I bought was the white and it was just to white for my taste. So I'm using the white for the first two coats of paint and then I'm going to follow with two coats of the their off white. It has a slight cream color to it and it looks great with the woodwork. It also doesn't blind you when you look at it with it's brilliance.
    On the mahogany trim I had some epifanes here and decided to go with it.
    As far as my trim for the edges of the main bulkheads here are a couple of pictures of the edge of one piece and you can see a did a dado on the backside to completely cover the edge of the plywood. The pieces are a glued up laminate and you can see my form to make them in my post number 145 of this gallery along with the glue I used. If you decide to go that way it is important to use a glue that hardens into a crystaline form so you don't get creep like you would with normal woodworking glue. Also if you go this way it is important to keep the slices of wood in the same order that you cut them from the board. It makes it much harder to detect that they are a bunch of strips glued up together. I've shown friends those pieces and until I told them how I made them they did not notice that it was strips glued together. Also in the past when I did glue ups like this I used to plane the surfaces of the pieces I glued together. These pieces had such a tight radius to follow that the pieces had to be so thin there was no way I could surface them. So I put a very good blade on the tablesaw and just ripped them off of a single board and kept them in order. After glue up you can't tell they were only surfaced with a saw blade. Oh and one last hint about the thickness of the pieces you glue together. The way to determine the thickness required for the individual strips is to slice a piece the thickness you think will work and then bend it around your form. If you can hold it tightly against the form around the entire curve without it breaking you are thin enough. If on the other had it snaps then cut another piece thinner and try again. Repeat the process until the piece is able to follow the form without breaking.
