reduced weight for added provisions
I took those lead pigs outta mine too....to allow for more beef stew. :DI already said that ---however as the provisions were used(I wonder where those tin cans are now) the boat would inevitably sit higher.BF'nD
Water Ballast????????????????????????????
Ya kno' its like I sez before----the lead pigs were removed to allow for more provisions.If ya' read the part about how I removed the v-berth cushions to allow formore storage space-----well picture this----8 five gallon sparkletts bottles in the v berth----4 each aligned amidships on eachside.now --as the water was used -----what to do with the empties???? hmmmmm----lesseeeee-----the vp-os plotting sheets-----with a felt tipped indelible marker(aka:sharpies)---I wrote notes on these sheets-who what where when----put them in the bottles----secured the plastic top reall good with sealant and duct tape-----man nowyaz" gotta real *****in message in a bottle----note -----this was done during the way back---outhere in nowheresville---1n 1985.where dooyaz' tink dey b' now?????????????/------totally encrusted with marine sea growth------turned crazed yellow by the sun----- probably half submerged by the shear weight of the encrusted barnacles-----or washed up on some tropical atoll------where my mind is when I think about it
Commander ballast question
I recently received the Ariel/Commander owners manual and maintenance guide and while reading it I learned something I did not previously know. It states that the ballast on the Commander inboard model is 2,500 lbs. lead casting set inside the keel and fiberglassed in place. But for the outboard model (which I believe is the way most of the Commanders were sold) there was an extra 500 lbs. lead casting which is portable and fits in the bottom of the keel.
My question is this. If I repower an outboard model with an inboard can the extra 500lbs. be removed without major surgery?
Thanks c_amos for your quick reply...
I tried a couple of searches before I asked the question but did not apparently hit on the right key words for the search.
That makes me feel better about my future plans.
