PS TESTING APRIL '06 edition
Page 10 of the April, 2006, Practical Sailor mag begins their test (in mud) of the following anchors:
Anchor Right Sarca
Bulwagga
Danforth Deep Set II
Davis Talon XT
Fortess FX-23
HydroBubble
Kingston Plow
Rocan 15
Spade A80
Super Max Pivoting
Super Max Rigid
XYZ
PS recommeds the Bulwagga, Davis Talon XT and the XYZ, which also gets a "best choice" star.
Yes, Ebb has issues with PS testing, but this is a comparative test without manufacturer hype. Grass and coral bottom testing should be done next :D
P.S. anchor tests (Ap '06)
Here are a few observations off the top:
Looks like P.S. photographed most of the hooks they used in their test for the article. It's amazing how the smooth silvery computer enhancements in the catalogs washed right off.
Rex's SARCA came away very well indeed and should lead to a change in the name to
SARAMCA. (sand and rock and mud combo anchor) Maybe somebody knows what percentage of mud anchoring there is in american waters. It makes this anchor imco look like real choice bower for the Ariel. Three anchors for the price of one (dividing its cost by 3) makes its expense a little easier to bear! Yes? It doesn't depend on weight for it to work. It looks, at the moment, like an ideal and versatile small cruiser hook.
A letter writer in the same issue quotes L. Francis Herreshoff (paraphase):
'The human race took millennia to develop a plow design that could be pulled easily through the earth, and some damned fool made an anchor of it.'
Referring to the CQR, which has faired rather badly in other testing. P.S. included a knockoff Kingston Plow in this group. It also dragged. But it is not clear if it ended up on its side when buried in the mud or stayed upright as we are to assume the HydroBubble does.
Danforth style anchors aside, nearly all of the rest fall into two groups. Ones with 'spoon' shaped blades, and the others with 'plow' shapes. This is a misnomer. Rocna literature also misnames their rival SARCA as a plow. But, excuse me, plow is the Kingston, the Davis Talon and the HydroBubble.
The mildly concave blade of the SARCA with its down pointing entry doesn't make it a plow. It's designed to dig in and down when pulled, while the heavy CQR (for example) is meant to part the earth and make a furrow. And this might be happening under steady pull at shorter angles with other plow shaped blades in mud.
In mud the spoons did not perform as well, especially in the 3:1 scope set and hold comparisons. Talking into my hat, I think the SuperMax, Rocna may have lifted off their set and had a ball of mud in their blade like we hear the Bruce has trouble with. What do you think?
The Hydro is a lightweight plow that keeps its blade at the correct attitude. Wonder how this anchor would perform in deeper water where its weight would be more neutral. IE there is something to be said for a heavy weight anchor you can be sure has a better chance digging in.
The all stainless XYZ. I would also call (like SARCA) a technical anchor. Its superb performance in mud means to me that it dives when pulled. I assume that the SARCA behaves similarly. It's not clear that XYZ will do that in or on other bottoms.
What are your conclusions? I will shy away from the distinct plow shapes AND most spoon shaped blades as I get closer to getting the ground gear together for 338.
last look at choosing a new anchor
Straight line pulling tests that Practical Sailor just published produces scewed results and imco (and many others) are pretty useless. If you were perched over a muck bottom in your Triton or A/C just about anything would keep you stuck there for awhile including a cinderblock or a CQR resting on its left side.
Most real world testing still favors our old standbys CQR and Danforth in ideal bottom conditions. We now have many new choices. And many serious cruisers are moving to the technibal hooks. The pointy spoon shaped anchors led by the French Spade are center stage. If anything can be garnered from straight pull testing it is that the spoon (like the claw and bruce for certain) shaped single blade MAY fill with a piece of the bottom (a piece of mud for instance) and keep the anchor from deeper set. This seems especially true for short scope (less than ideal) anchoring.
THE P.S. TEST SHOULD HAVE AT LEAST TESTED USING TUGGING AND SLIGHT ANGLE CHANGES. I feel these funky tests injure the reputation of Practical Sailor.
Hooped anchors are an attempt to improve on the single tine anchor design by rolling the anchor into its intended position for penetration. On flat firm bottom. The shank or arm of the anchor is attached at the back of the triangular blade, in the middle, and nearly at the front in a variety of designs. The Buegel, I believe the first production anchor with the hoop, may have been all along the ideal technical new age anchor. Their web site has a short essay of their philosophy. Personally, I'm one who has to touch things to understand them.
[IF WE CAN'T HAVE DECENT TESTING THEN LETS AT LEAST SEE THEM ALL LINED UP LIVE TOGETHER!}
While the Buegel is eveidently used succesfully in the Med (and as one wag put it: by mostly German cruisers) it may not be strong enough (I have no idea!) to be used as a storm bower for a small world cruiser. (The galvanized Rocna lookalike is a chunky hook.) I like the Beugel's spare, sleek look - I like its near straight blade with no apendages - it looks like it will slice into nearly any bottom the ocean can come up with like a knife! And when disengaged from the bottom will end up clean in the rollers. Yes???
WE ARE ALL STILL WAITING FOR REAL WORLD IMPARTIAL TESTING TO BE DONE COMPARING ALL THE NEW ANCHORS. IT MUST BE DONE NOW1 That's why this marina muck soup test thing is so uncalled for! Until then we are left with the hype and b.s. of the manufacturers and unsubstantiated opinion.
OK, now,
on to CHAIN and the anchor to chain connector....
{Sarca may well have in the physics of theie slotted blade and shank something quite unique. I really believe that if you tugged on a Sarca it would dive into the sand or muck whatever bottom. It (I'd have to see it and compare) is a concept departure from all the others.
From my perspective, which is heavily esthetic, the design has to be cleaned up and made less buzy. Sailors believe they are more sophisticated than the powerboat guys. If you are going to woo them from their awkward bowers and bulbous bruces, you gotta have a sexy simple form.)
