4 Attachment(s)
Some Days You Just Get Lucky
I am just about done with rehabbing the hull and deck and about to start with the repower project. I am going to install a Yanmar 2GM. The boat was originally powered with an outboard so I figured I would start to poke around and see what was involved with cutting the window in the keel and rudder, installing the shaft log and building an engine bed. When I started to sound the keel where the window should be I noticed a decidedly different sound. It sounded like a different laminate schedule than the rest of the keel so I cut a bit out and discovered that the boat was built for an inboard and they glassed over the window. A little cutting and a few minutes with a pry bar and viola. I have my keel window. I was prepared for a fairly involved glass job and now all I have to do is clean up a little tabbing and install the shaft log. I hope the rudder is as easy. It appears the stock is set up for a window too. I'll keep my fingers crossed.
Attachment 9756
Attachment 9757
Attachment 9759
Attachment 9758
